VIGAS 25 LC optimization topics
There is 1 reply in this Thread which was already clicked 3,061 times. The last Post () by Klipp.
  • Hi Guys
    I am sorry for my english languge but my German is not very good.
    I have new Vigas 25 LC.
    I would like to check some optimizations that you have done but it is really hard to check all the topics because like I said my German language
    is not so good.
    Can you please direct me, on links from this forum, where best vigas 25 optimization topics are discused.
    I already have home made turbolatoras. I have seen other things here like change of the burning chanber things done with air and so on.
    So I would really appritiate if you can just put here the links to the relevat topics and I will try to fight over them and try to translate :) to my self.
    It will also be a good German language pratice for me :)
    Thanks Again.
  • Hi
    easy, not that problem to get to a thread that comfort your wishes in optimization.
    The discussed carburetor type is not "lamda" controlled but it fits yours in size and in the end tuned to the max.
    http://www.holzvergaser-forum.…um/index.php?thread/15784
    This is about your carburator
    http://www.holzvergaser-forum.…um/index.php?thread/16589
    Most projects reffering to a complete solution (compete heating system) are mentioned at
    "MEIN HEIZUNGSPROJEKT"
    In your other posting i've seen you've allready found the tuning section.
    hopefully this will work it out for you
    Mike
    40Kw HVS-E/LC
    5000L Puffer
    2x500L ADG
    2xUVR1611
