There are 13 replies in this Thread which was already clicked 7,624 times. The last Post () by Matejmes.
  • Hello everyone!
    I am wondering if anybody can help me - which software do I have to use, to view the recorded data of boiler operation stored on sd card?
    Thank you for your answer,
    Matej
  • hey,
    so far I understand the AK 3000 M is only a programmer for updating the firmware on the AK 3000 S. Most probably the sd-card is used for transfering that piece of software and not for any logging services.
    cheers!
  • Hello k4ktus,
    the modul also has the ability to monitor boiler operation. Function can be turned on or off in service menu. I can get the file from SD card but I cant use it... It´s extention is .137
    Thank you for your reply,
    Cheers!
  • y u are not ask ERS for more information. On the German webpages there's nothing mentioned about data logging. As my Slovakian is very bad I'm not able to unterstand everthing from that site, even with google translation ;)
    http://www.ers.sk/
  • I have already written to them - I was told, that some other company is now making controllers for Vigas. I also got a contact, but no reply... So I tried here too...
    Cheers!
  • have you tried to open the file with simple text editor? Like pspad or something? I'm not awaiting any binary data in such a case. The file is most likely a serial dump in ascii.
  • that I can do... This is a small part from the log file:
    "7ERS V4.53 AK AK3001 V1.37 AK3000M V1.36 11/03/14 11:54 11/11/21 11:39 11/05/24 16:00 @
    ™F›Ä B›
    «B dęF dęFŹÂ ÍĚ@ G@ 8‡E }Ků? d P˙ , END˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙@
    ™FŠÔ B@ŰŞB dęF dęFŹÂ ÍĚ@ úţF@ €‡E Sů? d P˙ , END˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙@
    ™FÂŰ BߤŞB dęF dęFŽ‘Â ÍĚ@ G@ @E ‰Zů? d P˙ , END˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙@
    ™F´ç BrŞB dęF dęFŽ‘Â ÍĚ@ G@ °‡E ‰Zů? d P˙ , END˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙@
    ™FŁ÷ B(@ŞB dęF dęFŽ‘Â ÍĚ@ G@ °‡E [mů? d P˙ , END˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙@
    $ ™F^ü B"ŞB dęF dęFŽ‘Â ÍĚ@
    G@ ¨‡E l|ů? d P˙ , END˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙@
    * ™FLˇBŹó©B dęF dęFŹÂ ÍĚ@ G@ †E l|ů? d P˙ , END˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙@
    0 ™F?ˇB\Ë©B dęF dęFŹÂ ÍĚ@
    G@ h†E ~‹ů? d P˙ , END˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙@"
  • Hello k4ktus,
    this is the file from sd card, which should represent boiler monitoring. If you find out how to use it, you would make me very happy....
    Cheers,
    Matej
  • Hey matej,
    had have a look on that data. But to be honestly, I'm not good in identifying patterns. So it would be nice whenever you are doing a new log, to write down the time and the values for some time. Especial at the beginning.
  • k4ktus!
    I managed to get original software, so now I can use the readings myself.
    Thank you very much for your effort, trying to help me.
    Cheers,
    Matej
  • hey matjei, no problem! But it would be nice to know where to get the software. Actual not for me but for the forum.
    keep burnin, bro!
  • Hey k4ktus!
    Eventually I got if from reseller. At first, I was told that the software is intedndet to technicians and service-men as diagnosis tool, but at the and I got it, and I can say it works - the software interprets the data and then converts it to xls document.
    Since the heating season is starting, I beleive we will heare again very soon...
    Cheers,
    Matej
