Source für Wochenschaltuhr
There is 1 reply in this Thread which was already clicked 2,954 times. The last Post () by k4ktus.
  • Hier kommt mal ein Schnippsel vllt. hilft es dem Einen oder Anderen:
    Wer die gesammte Klasse brauchen kann soll sich melden. Feedback freut mich natürlich auch :)
    [code type=diff]/**********************************************************************************************
    * Arduino programmable timer Library - Version 0.1b
    * by Simon Bauer seimen.baua beiundoder gmail.com
    * This Library is licensed under a GPLv3 License
    #include <programmableTimer.h>
    #include <Time/Time.h>
    #include <stdint.h>
    int programmableTimer::status(const int controllTable[7][8], const time_t &myTime, const int &checkIntervallSec)
    //test it for 1 = activated 0=deactivated -1= no intervall found i.e. 0000 0000 intervalls in table
    recentTime = hour(myTime) * 100 + minute(myTime); //Maybe without parameter
    recentWeekDay = weekday(myTime);
    if (recentTime - myOldTime >= checkIntervallSec) //Zero means no pause. Otherwise every x seconds will be check for new status.
    myOldTime = recentTime;
    if ( controllTable[recentWeekDay][NoTimeOn] <= recentTime && controllTable [recentWeekDay][NoTimeOn+1] >= recentTime)
    if (statusBit == 0){ NoTimeOff = NoTimeOn + 1; }
    statusBit = 1;
    return statusBit;
    else if ( controllTable[recentWeekDay][NoTimeOff+1] >= recentTime && controllTable[recentWeekDay][NoTimeOff] <= recentTime )
    if (statusBit == 1){ NoTimeOn = NoTimeOff + 1; }
    statusBit = 0;
    return statusBit;
    else if ( recentTime <= controllTable[recentWeekDay][0]) //day changed
    NoTimeOn=0;
    NoTimeOff = 1;
    statusBit = 0;
    return -1;
    else //the intervall may not fit to the recent time
    NoTimeOn = NoTimeOn + 2;
    if (NoTimeOn == 8) //reset counter
    NoTimeOn=0;
    NoTimeOff = 1;
    programmableTimer::programmableTimer()
    NoTimeOn = 0;
    NoTimeOff = 1;
    programmableTimer::~programmableTimer()
    }[/code]
  • Grr kann den Beitrag leider nicht mehr ändern! War noch ein kleiner Fehler drin.
    In der nächsten Revision werde ich die Klasse dann dynamisch machen d.h es können beliebig viele Schaltintervalle übergeben werden.
    [code type=ini]/**********************************************************************************************
    * by Simon Bauer seimen.baua atund oder nich gmail.com
    #include <stdint.h>
    //test it for 1 = activated 0=deactivated (-1= no intervall found i.e. 0000 0000 intervalls in table) not used for now
    statusBit = 1;
    return statusBit;
    statusBit = 0;
    return statusBit;
    NoTimeOn=0;
    NoTimeOff = 1;
    statusBit = 0;
    return statusBit;
    NoTimeOn=0;
    NoTimeOff = 1;
    NoTimeOn = 0;
    NoTimeOff = 1;
    }[/code]
