Jetzt sieht es besser aus,
ich hatte den Eintrag - /linux_p4d/logs/p4d.log:/var/log/p4d.log an die falsche Stelle im Docker-Compose.yml
eingetragen.
Und das seht in Log wenn ich den init system menue mache
Feb 8 15:09:06 e0803c43cf5c p4d: Store samples ..
Feb 8 15:09:06 e0803c43cf5c p4d: Stored 12 samples
Feb 8 15:09:06 e0803c43cf5c p4d: Updating error list
Feb 8 15:09:08 e0803c43cf5c p4d: Updating error list done in 1631ms
Feb 8 15:09:08 e0803c43cf5c p4d: Info: Found (4) pending errors
Feb 8 15:09:08 e0803c43cf5c p4d: total: 0 minutes
Feb 8 15:09:36 e0803c43cf5c p4d: Checking state ...
Feb 8 15:09:36 e0803c43cf5c p4d: ... got (72) 'SH Heizen'
Feb 8 15:09:36 e0803c43cf5c p4d: -> (node-red) (p4d2mqtt/changes) [{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "txt", "state": "off", "value": 72.0, "action": "CHANGE"}]
Feb 8 15:09:36 e0803c43cf5c p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "txt", "state": "off", "value": 72.0, "action": "CHANGE"}]
Feb 8 15:10:05 e0803c43cf5c p4d: Got wrong communication id fd00 expected 02fd
Feb 8 15:10:05 e0803c43cf5c p4d: Read 236 menu items
Feb 8 15:10:06 e0803c43cf5c p4d: Checking state ...
Feb 8 15:10:06 e0803c43cf5c p4d: Got wrong communication id e202 expected 02fd
Feb 8 15:10:06 e0803c43cf5c p4d: Got 18 unexpected bytes
Feb 8 15:10:06 e0803c43cf5c p4d: Closing io device
Feb 8 15:10:06 e0803c43cf5c p4d: Error reading serial interface, reopen now!
Feb 8 15:10:06 e0803c43cf5c p4d: Opening '/dev/ttyUSB0' succeeded!
Feb 8 15:10:06 e0803c43cf5c p4d: ... got (72) 'SH Heizen'
Feb 8 15:10:06 e0803c43cf5c p4d: -> (node-red) (p4d2mqtt/changes) [{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "txt", "state": "off", "value": 72.0, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "txt", "state": "off", "value": 72.0, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: State changed to 'SH Heizen'
Feb 8 15:10:06 e0803c43cf5c p4d: -> (node-red) (p4d2mqtt/changes) [{"id": "UD:0x02", "type": "UD", "name": "Betriebsart Kessel", "unit": "zst", "state": "off", "value": 5.0, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x02", "type": "UD", "name": "Betriebsart Kessel", "unit": "zst", "state": "off", "value": 5.0, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: -> (node-red) (p4d2mqtt/changes) [{"id": "VA:0x01", "type": "VA", "name": "AGT", "unit": "°C", "state": "off", "value": 145.0, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: -> (p4d2mqtt/changes)[{"id": "VA:0x01", "type": "VA", "name": "AGT", "unit": "°C", "state": "off", "value": 145.0, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: -> (node-red) (p4d2mqtt/changes) [{"id": "VA:0x03", "type": "VA", "name": "Rest %", "unit": "%", "state": "off", "value": 17.5, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: -> (p4d2mqtt/changes)[{"id": "VA:0x03", "type": "VA", "name": "Rest %", "unit": "%", "state": "off", "value": 17.5, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: -> (node-red) (p4d2mqtt/changes) [{"id": "VA:0x07", "type": "VA", "name": "Saugzugdrehzahl", "unit": "U", "state": "off", "value": 2841.0, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: -> (p4d2mqtt/changes)[{"id": "VA:0x07", "type": "VA", "name": "Saugzugdrehzahl", "unit": "U", "state": "off", "value": 2841.0, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: -> (node-red) (p4d2mqtt/changes) [{"id": "VA:0x8b", "type": "VA", "name": "Solarfühler Pufferunten", "unit": "°C", "state": "off", "value": 59.0, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: -> (p4d2mqtt/changes)[{"id": "VA:0x8b", "type": "VA", "name": "Solarfühler Pufferunten", "unit": "°C", "state": "off", "value": 59.0, "action": "CHANGE"}]
Feb 8 15:10:06 e0803c43cf5c p4d: Update script sensors
Feb 8 15:10:06 e0803c43cf5c p4d: Store samples ..
Feb 8 15:10:06 e0803c43cf5c p4d: Stored 12 samples
Feb 8 15:10:06 e0803c43cf5c p4d: Updating error list
Feb 8 15:10:08 e0803c43cf5c p4d: Updating error list done in 1617ms
Feb 8 15:10:08 e0803c43cf5c p4d: Info: Found (4) pending errors
Feb 8 15:10:08 e0803c43cf5c p4d: total: 0 minutes
Feb 8 15:10:08 e0803c43cf5c p4d: Info: No update from MQTT since '08.02.2022 15:05:05', disconnect from MQTT to force recover
Feb 8 15:10:08 e0803c43cf5c p4d: Disconnected from MQTT
Feb 8 15:10:08 e0803c43cf5c p4d: Error: MQTT connection broken, trying reconnect
Feb 8 15:10:08 e0803c43cf5c p4d: MQTT: Connecting publisher to 'tcp://localhost:1883' succeeded
Feb 8 15:10:08 e0803c43cf5c p4d: MQTT: Connecting subscriber to 'tcp://localhost:1883' succeeded
Feb 8 15:10:08 e0803c43cf5c p4d: MQTT: Connecting subscriber to 'tcp://localhost:1883' - 'p4d2mqtt/w1/#' succeeded
Feb 8 15:10:08 e0803c43cf5c p4d: MQTT: Connecting subscriber to 'tcp://localhost:1883' - 'p4d2mqtt/arduino/out' succeeded
Feb 8 15:10:08 e0803c43cf5c p4d: MQTT: Connecting subscriber to 'tcp://localhost:1883' - 'p4d2mqtt/light/+/set/#' succeeded
Feb 8 15:10:09 e0803c43cf5c p4d: MQTT: Connecting subscriber to 'tcp://localhost:1883' - 'p4d2mqtt/command/#' succeeded
Feb 8 15:10:09 e0803c43cf5c p4d: MQTT: Connecting subscriber to 'tcp://localhost:1883' - 'p4d2mqtt/nodered/#' succeeded
