hier die letzten 80Einträge im log.
1x ist die MQTT Verindung abgebrochen ("MQTT connection broken"). In 500 Zeilen Log waren es 3 Abbrüche. Also kein Einzelfall
Apr 3 22:45:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Pufferladezustand_0x1bf/state)[{"value": 78.0}]
Apr 3 22:45:03 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "VA:0x1bf", "type": "VA", "name": "Pufferladezustand", "unit": "%", "state": "off", "value": 78.0, "action": "CHANGE"}]
Apr 3 22:45:03 raspberrypi p4d: Update script sensors
Apr 3 22:45:03 raspberrypi p4d: Store samples ..
Apr 3 22:45:03 raspberrypi p4d: Stored 10 samples
Apr 3 22:45:03 raspberrypi p4d: Updating error list
Apr 3 22:45:04 raspberrypi p4d: Updating error list done in 1605ms
Apr 3 22:45:07 raspberrypi p4d: No update from MQTT since '03.04.2022 22:40:06', disconnect from MQTT to force recover
Apr 3 22:45:07 raspberrypi p4d: Disconnected from MQTT
Apr 3 22:45:07 raspberrypi p4d: Error: MQTT connection broken, trying reconnect
Apr 3 22:45:07 raspberrypi p4d: MQTT: Connecting publisher to 'tcp://192.168.0.5:1883' succeeded
Apr 3 22:45:07 raspberrypi p4d: MQTT: Connecting subscriber to 'tcp://192.168.0.5:1883' succeeded
Apr 3 22:45:07 raspberrypi p4d: MQTT: Connecting subscriber to 'tcp://192.168.0.5:1883' - 'p4d2mqtt/ping/#' succeeded
Apr 3 22:45:07 raspberrypi p4d: MQTT: Connecting subscriber to 'tcp://192.168.0.5:1883' - 'p4d2mqtt/light/+/set/#' succeeded
Apr 3 22:45:07 raspberrypi p4d: MQTT: Connecting subscriber to 'tcp://192.168.0.5:1883' - 'p4d2mqtt/command/#' succeeded
Apr 3 22:45:07 raspberrypi p4d: MQTT: Connecting subscriber to 'tcp://192.168.0.5:1883' - 'p4d2mqtt/nodered/#' succeeded
Apr 3 22:45:08 raspberrypi p4d: -> (p4d2mqtt/ping)[{"ping" : true, "sender" : "p4d"}]
Apr 3 22:45:09 raspberrypi p4d: <- (p4d2mqtt/ping) [{"ping" : true, "sender" : "p4d"}] retained 1
Apr 3 22:45:13 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:45:13 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:45:23 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:45:23 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:45:33 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:45:33 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:45:39 raspberrypi p4d: -> (p4d2mqtt/ping)[{"ping" : true, "sender" : "p4d"}]
Apr 3 22:45:43 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:45:43 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:45:53 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:45:53 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/sensor/State_Duration_3/state)[{"value": 642.0}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/sensor/State_Duration_19/state)[{"value": 548.0}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Betriebsart_Kessel/state)[{"value": "Automatik"}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x02", "type": "UD", "name": "Betriebsart Kessel", "unit": "", "state": "off", "value": 2.0, "action": "CHANGE"}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Kesseltemperatur_0x0/state)[{"value": 86.0}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "VA:0x00", "type": "VA", "name": "Kesseltemperatur", "unit": "°C", "state": "off", "value": 86.0, "action": "CHANGE"}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Aussentemperatur_0x4/state)[{"value": 2.0}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/sensor/BetriebsartHeizkreis_0x1f/state)[{"value": 0.0}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/sensor/BetriebsartHeizkreis_0x2f/state)[{"value": 0.0}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Pufferladezustand_0x1bf/state)[{"value": 79.0}]
Apr 3 22:46:03 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "VA:0x1bf", "type": "VA", "name": "Pufferladezustand", "unit": "%", "state": "off", "value": 79.0, "action": "CHANGE"}]
Apr 3 22:46:03 raspberrypi p4d: Update script sensors
Apr 3 22:46:03 raspberrypi p4d: Store samples ..
Apr 3 22:46:03 raspberrypi p4d: Stored 10 samples
Apr 3 22:46:03 raspberrypi p4d: Updating error list
Apr 3 22:46:04 raspberrypi p4d: Updating error list done in 1608ms
Apr 3 22:46:10 raspberrypi p4d: -> (p4d2mqtt/ping)[{"ping" : true, "sender" : "p4d"}]
Apr 3 22:46:13 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:46:13 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:46:23 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:46:23 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:46:33 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:46:33 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:46:41 raspberrypi p4d: -> (p4d2mqtt/ping)[{"ping" : true, "sender" : "p4d"}]
Apr 3 22:46:43 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:46:43 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:46:53 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:46:53 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Stoker leeren"}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x01", "type": "UD", "name": "Heizungsstatus", "unit": "", "state": "off", "value": 21.0, "action": "CHANGE"}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/sensor/State_Duration_3/state)[{"value": 642.0}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/sensor/State_Duration_19/state)[{"value": 548.0}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Betriebsart_Kessel/state)[{"value": "Automatik"}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "UD:0x02", "type": "UD", "name": "Betriebsart Kessel", "unit": "", "state": "off", "value": 2.0, "action": "CHANGE"}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Kesseltemperatur_0x0/state)[{"value": 87.0}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "VA:0x00", "type": "VA", "name": "Kesseltemperatur", "unit": "°C", "state": "off", "value": 87.0, "action": "CHANGE"}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Aussentemperatur_0x4/state)[{"value": 2.0}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/sensor/BetriebsartHeizkreis_0x1f/state)[{"value": 0.0}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/sensor/BetriebsartHeizkreis_0x2f/state)[{"value": 0.0}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/sensor/Pufferladezustand_0x1bf/state)[{"value": 80.0}]
Apr 3 22:47:03 raspberrypi p4d: -> (p4d2mqtt/changes)[{"id": "VA:0x1bf", "type": "VA", "name": "Pufferladezustand", "unit": "%", "state": "off", "value": 80.0, "action": "CHANGE"}]
Apr 3 22:47:03 raspberrypi p4d: Update script sensors
Apr 3 22:47:03 raspberrypi p4d: Store samples ..
Apr 3 22:47:03 raspberrypi p4d: Stored 10 samples
Apr 3 22:47:03 raspberrypi p4d: Updating error list
Apr 3 22:47:04 raspberrypi p4d: Updating error list done in 1610ms
Alles anzeigen
