Dann viele Fehler:
/usr/include/aarch64-linux-gnu/curl/curl.h:1195:3: note: declared here
1195 | CURLOPTDEPRECATED(CURLOPT_HTTPPOST, CURLOPTTYPE_OBJECTPOINT, 24,
g++ -c -ggdb -O0 -pthread -fPIC -std=c++17 -Wall -Wreturn-type -Wformat -pedantic -Wunused-variable -Wunused-label -Wunused-value -Wunused-function -Wno-long-long -Wno-unused-parameter -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -Wno-psabi -I/usr/include/mariadb -I/usr/include/mariadb/mysql -D_GNU_SOURCE -DTARGET='"p4d"' -DCLASS='P4d' -DNAME='"p4"' -DLOG_PREFIX='""' -DUSEUUID -DUSEMD5 -DUSELIBARCHIVE -DUSEJSON -DUSEGUNZIP -DUSEDB -DBIN_PATH='"/usr/local/bin"' -D_NO_RASPBERRY_PI_ -DGIT_REV='"eacaf7c"' -o lib/thread.o lib/thread.c
lib/thread.c: In constructor ‘cThread::cThread(const char*, bool)’:
lib/thread.c:66:3: error: ‘pthread_attr_init’ was not declared in this scope; did you mean ‘pthread_attr_t’?
66 | pthread_attr_init(&attr);
| pthread_attr_t
lib/thread.c: In destructor ‘virtual cThread::~cThread()’:
lib/thread.c:73:3: error: ‘pthread_attr_destroy’ was not declared in this scope; did you mean ‘pthread_attr_t’?
73 | pthread_attr_destroy(&attr);
| pthread_attr_t
lib/thread.c: In member function ‘bool cThread::Start(int, int)’:
lib/thread.c:166:18: error: ‘pthread_create’ was not declared in this scope; did you mean ‘timer_create’?
166 | res = pthread_create(&childTid, 0, (void*(*)(void*))&StartThread, (void*)this);
| timer_create
lib/thread.c:170:12: error: ‘pthread_attr_setstacksize’ was not declared in this scope
170 | pthread_attr_setstacksize(&attr, stackSize);
lib/thread.c:171:18: error: ‘pthread_create’ was not declared in this scope; did you mean ‘timer_create’?
171 | res = pthread_create(&childTid, &attr, (void*(*)(void*))&StartThread, (void*)this);
| timer_create
lib/thread.c:176:12: error: ‘pthread_detach’ was not declared in this scope; did you mean ‘pthread_t’?
176 | pthread_detach(childTid); // auto-reap
| pthread_t
lib/thread.c: In member function ‘void cThread::Cancel(int)’:
lib/thread.c:230:6: error: ‘pthread_cancel’ was not declared in this scope; did you mean ‘pthread_once_t’?
230 | pthread_cancel(childTid);
| pthread_once_t
lib/thread.c: In constructor ‘cCondWait::cCondWait()’:
lib/thread.c:248:4: error: ‘pthread_mutex_init’ was not declared in this scope; did you mean ‘pthread_mutex_t’?
248 | pthread_mutex_init(&mutex, NULL);
| pthread_mutex_t
lib/thread.c:249:4: error: ‘pthread_cond_init’ was not declared in this scope; did you mean ‘pthread_cond_t’?
249 | pthread_cond_init(&cond, NULL);
| pthread_cond_t
lib/thread.c: In destructor ‘cCondWait::~cCondWait()’:
lib/thread.c:254:4: error: ‘pthread_cond_broadcast’ was not declared in this scope; did you mean ‘pthread_condattr_t’?
254 | pthread_cond_broadcast(&cond); // wake up any sleepers
| pthread_condattr_t
lib/thread.c:255:4: error: ‘pthread_cond_destroy’ was not declared in this scope; did you mean ‘pthread_condattr_t’?
255 | pthread_cond_destroy(&cond);
| pthread_condattr_t
lib/thread.c:256:4: error: ‘pthread_mutex_destroy’ was not declared in this scope; did you mean ‘pthread_mutexattr_t’?
256 | pthread_mutex_destroy(&mutex);
| pthread_mutexattr_t
lib/thread.c: In member function ‘bool cCondWait::Wait(int)’:
lib/thread.c:267:4: error: ‘pthread_mutex_lock’ was not declared in this scope; did you mean ‘pthread_mutex_t’?
267 | pthread_mutex_lock(&mutex);
| pthread_mutex_t
lib/thread.c:279:20: error: ‘pthread_cond_timedwait’ was not declared in this scope; did you mean ‘pthread_condattr_t’?
279 | if (pthread_cond_timedwait(&cond, &mutex, &abstime) == ETIMEDOUT)
| pthread_condattr_t
lib/thread.c:285:10: error: ‘pthread_cond_wait’ was not declared in this scope; did you mean ‘pthread_cond_t’?
285 | pthread_cond_wait(&cond, &mutex);
| pthread_cond_t
lib/thread.c:290:4: error: ‘pthread_mutex_unlock’ was not declared in this scope; did you mean ‘pthread_mutex_t’?
290 | pthread_mutex_unlock(&mutex);
| pthread_mutex_t
lib/thread.c: In member function ‘void cCondWait::Signal()’:
lib/thread.c:297:4: error: ‘pthread_mutex_lock’ was not declared in this scope; did you mean ‘pthread_mutex_t’?
297 | pthread_mutex_lock(&mutex);
| pthread_mutex_t
lib/thread.c:299:4: error: ‘pthread_cond_broadcast’ was not declared in this scope; did you mean ‘pthread_condattr_t’?
299 | pthread_cond_broadcast(&cond);
| pthread_condattr_t
lib/thread.c:300:4: error: ‘pthread_mutex_unlock’ was not declared in this scope; did you mean ‘pthread_mutex_t’?
300 | pthread_mutex_unlock(&mutex);
| pthread_mutex_t
lib/thread.c: In constructor ‘cCondVar::cCondVar()’:
lib/thread.c:309:4: error: ‘pthread_cond_init’ was not declared in this scope; did you mean ‘pthread_cond_t’?
309 | pthread_cond_init(&cond, 0);
| pthread_cond_t
lib/thread.c: In destructor ‘cCondVar::~cCondVar()’:
lib/thread.c:314:4: error: ‘pthread_cond_broadcast’ was not declared in this scope; did you mean ‘pthread_condattr_t’?
314 | pthread_cond_broadcast(&cond); // wake up any sleepers
| pthread_condattr_t
lib/thread.c:315:4: error: ‘pthread_cond_destroy’ was not declared in this scope; did you mean ‘pthread_condattr_t’?
315 | pthread_cond_destroy(&cond);
| pthread_condattr_t
lib/thread.c: In member function ‘void cCondVar::Wait(cMyMutex&)’:
lib/thread.c:325:7: error: ‘pthread_cond_wait’ was not declared in this scope; did you mean ‘pthread_cond_t’?
325 | pthread_cond_wait(&cond, &Mutex.mutex);
| pthread_cond_t
lib/thread.c: In member function ‘bool cCondVar::TimedWait(cMyMutex&, int)’:
lib/thread.c:347:14: error: ‘pthread_cond_timedwait’ was not declared in this scope; did you mean ‘pthread_condattr_t’?
347 | if (pthread_cond_timedwait(&cond, &Mutex.mutex, &abstime) == ETIMEDOUT)
| pthread_condattr_t
lib/thread.c: In member function ‘void cCondVar::Broadcast()’:
lib/thread.c:359:4: error: ‘pthread_cond_broadcast’ was not declared in this scope; did you mean ‘pthread_condattr_t’?
359 | pthread_cond_broadcast(&cond);
| pthread_condattr_t
make: *** [Make.config:110: lib/thread.o] Fehler 1
