Looks ok for me.
Thanks Reichl,
Looking your stats it seems your s4 is more stable than mine.
I noticed that you set gas temperature at 180 and lambda at 6%?
Which are pros and cons to set lambda at low value ex 6?
Thanks
Es gibt 22 Antworten in diesem Thema, welches 8.294 mal aufgerufen wurde. Der letzte Beitrag () ist von mare.
Looks ok for me.
Thanks Reichl,
Thanks
I only have a 15kW that has lower default exhaust temp.
And a brand new chimney that can stand condensation and 60°C on top.
So 180°C is fine for me.
6% O2 was once a trial value and I just kept it.
Because of the low max exhaust temp. my S4 sometimes goes below 50% load, you remember "Kesselsteuerung".
I will therefore measure my burning temperature in the turbo chamber if it still reaches 900°C. But this will take time....
28kw has wider turbolators. Flue gas stays longer in your boiler/kessel. So its normal thats your fan runs beetween 80% and 95%. the 28kw version just burn faster than 22kw. It also depends how thick your wood is splited and how dry it is.
