Probleme mit p4d auf meinem Fröling PE1 mit P3200 Touch
There are 15 replies in this Thread which was already clicked 5,684 times. The last Post () by manzznam.
    Ich habe mir meinen RaspberryPi mittels Serial to USB (FTDI) Kabel auf meinen Fröling PE1 auf COM1 (neben Touchdisplay unter Ofenabdeckung) gehängt und mir dann p4d installiert.
    Nur anscheinend kommen keine Daten über die Schnittstelle rein. Ich poste am besten mal das Syslog und das Log vom p4d service.
    Syslog:
    Apr 10 11:52:14 raspberrypi systemd[1]: Stopping P4d Control Deamon...
    Apr 10 11:52:14 raspberrypi systemd[1]: p4d.service: Succeeded.
    Apr 10 11:52:14 raspberrypi systemd[1]: Stopped P4d Control Deamon.
    Apr 10 11:52:14 raspberrypi systemd[1]: p4d.service: Consumed 10.012s CPU time.
    Apr 10 11:52:19 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:52:29 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:52:39 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:52:49 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:52:59 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:53:09 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:53:19 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:53:29 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:53:39 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:53:49 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:53:57 raspberrypi kernel: [ 629.351345] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
    Apr 10 11:53:57 raspberrypi kernel: [ 629.510052] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
    Apr 10 11:53:57 raspberrypi kernel: [ 629.510088] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    Apr 10 11:53:57 raspberrypi kernel: [ 629.510102] usb 1-1.3: Product: FT232R USB UART
    Apr 10 11:53:57 raspberrypi kernel: [ 629.510112] usb 1-1.3: Manufacturer: FTDI
    Apr 10 11:53:57 raspberrypi kernel: [ 629.510122] usb 1-1.3: SerialNumber: AB70S4G4
    Apr 10 11:53:57 raspberrypi kernel: [ 629.519408] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
    Apr 10 11:53:57 raspberrypi kernel: [ 629.519566] usb 1-1.3: Detected FT232R
    Apr 10 11:53:57 raspberrypi kernel: [ 629.521107] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
    Apr 10 11:53:57 raspberrypi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
    Apr 10 11:53:57 raspberrypi mtp-probe: bus: 1, device: 5 was not an MTP device
    Apr 10 11:53:59 raspberrypi ModemManager[567]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3': not supported by any plugin
    Apr 10 11:53:59 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:54:09 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:54:19 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:54:29 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:54:39 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:54:49 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:54:59 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:55:09 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:55:19 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:55:22 raspberrypi systemd[1]: Starting P4d Control Deamon...
    Apr 10 11:55:22 raspberrypi systemd[1]: Started P4d Control Deamon.
    Apr 10 11:55:29 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:55:39 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    Apr 10 11:55:49 raspberrypi w1mqtt: Info: No One-Wire sensors found, path '/sys/bus/w1/devices' not exist (No such file or directory)
    und hier das Log vom Service:
    pi@raspberrypi:~ $ systemctl status p4d
    * p4d.service - P4d Control Deamon
    Loaded: loaded (/etc/systemd/system/p4d.service; enabled; vendor preset: enabled)
    Active: active (running) since Mon 2023-04-10 11:55:22 CEST; 1min 44s ago
    Process: 1546 ExecStart=/usr/bin/p4d (code=exited, status=0/SUCCESS)
    Main PID: 1547 (p4d)
    Tasks: 4 (limit: 1595)
    CPU: 2.267s
    CGroup: /system.slice/p4d.service
    `-1547 /usr/bin/p4d
    Apr 10 11:56:57 raspberrypi p4d[1547]: Read word failed, aborting
    Apr 10 11:56:57 raspberrypi p4d[1547]: Error reading serial interface, reopen now!
    Apr 10 11:56:59 raspberrypi p4d[1547]: Read word failed, aborting
    Apr 10 11:56:59 raspberrypi p4d[1547]: Error reading serial interface, reopen now!
    Apr 10 11:57:01 raspberrypi p4d[1547]: Read word failed, aborting
    Apr 10 11:57:01 raspberrypi p4d[1547]: Error reading serial interface, reopen now!
    Apr 10 11:57:03 raspberrypi p4d[1547]: Read word failed, aborting
    Apr 10 11:57:03 raspberrypi p4d[1547]: Error reading serial interface, reopen now!
    Apr 10 11:57:05 raspberrypi p4d[1547]: Read word failed, aborting
    Apr 10 11:57:05 raspberrypi p4d[1547]: Error reading serial interface, reopen now!
    Als USB Kabel hab ich folgendes verwendet: https://www.amazon.de/dp/B0758…o2ov_dt_b_product_details
    Zusätzlich hab ich einen Gender Changer auf den Anschluss am Ofen verwendet: https://www.amazon.de/dp/B00BB…dt_b_product_details&th=1
    Die WebUI sieht so aus. Nur ist anscheinend keine Websocket Verbindung verfügbar:
    Hat vielleicht jemand eine Idee an was es liegen könnte? Kann man auch irgendwie direkt prüfen ob Signale über COM1 empfangen werden?
    LG
    Manfred
  • Ich habe mir meinen RaspberryPi mittels Serial to USB (FTDI) Kabel auf meinen Fröling PE1 auf COM1 (neben Touchdisplay unter Ofenabdeckung) gehängt und mir dann p4d installiert.
    Was sagt p4 state auf der Kommandozeile?
    Bei mir:
    Code
    $ p4 state
    Version: 50.04.05.20
    Time: Monday, 10. Apr. 2023 14:40:58
    2 - Automatik
    19 - Betriebsbereit
    Wenn Du im Syslog diese Meldungen meinst, die habe ich auch:
  • Wenn Du im Syslog diese Meldungen meinst, die habe ich auch...
    Wenn Du keine 1w-Sensoren hast:
    systemctl stop w1mqtt
    Dann auf Dauer:
    systemctl disable w1mqtt
    Vielleicht hilft das?
  • Also wenn ich "p4 state" mache kommt:
    Code
    pi@raspberrypi:~ $ p4 state
    Um die Info w1mqtt Ausgaben gings mir eigentlich gar nicht, aber gut zu wissen dass ich die deaktivieren kann.
    Muss ich im p4d irgendwo mal einstellen welcher COM Port oder welche Baudrate? Oder sollte der p4d alles automatisch erkennen und Daten erhalten?
    Kann es auch am USB Kabel liegen? Könnt ihr RS232->USB Kabel empfehlen die funktionieren?
  • Um die Info w1mqtt Ausgaben gings mir eigentlich gar nicht...
    Sorry, ich habe das Log auch nur überflogen... :saint:
    Das Problem scheint ja hier zu liegen:
    Code
    Auf die Schnelle habe ich diesen Tipp gefunden (ohne Garantie):
    Open an lxterminal window and try entering man modprobe, the system will attempt to explain it to you.
  • Also meines Wissens ist die Meldung ja ok. Der Adapter ist ja auch kein MTP Device (so wie zb eine Digitalkamera oder externe Festplatte).
    Wenn ich eingebe:
    Code
    pi@raspberrypi:~ $ dmesg | grep FTDI
    [ 4.529196] usb 1-1.3: Manufacturer: FTDI
    [ 9.151688] usbserial: USB Serial support registered for FTDI USB Serial Device
    [ 9.152024] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
    [ 9.162648] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
    schaut eigentlich auch alles ok aus. Also wurde das Kabel auch als FTDI Device erkannt ...
    Ich verstehe nur nicht warum keine Daten kommen ...
  • Hallo Manfred,
    nur die nachfolgenden Zeilen sind für dein USB-Kabel mit ttyUSB0 relevant, der Rest hat damit nichts zu tun.
    USB-Kabel mit FTDI UART sind normalerweise sehr gut und funktionieren problemlos mit allen linux-systemen.
    Was mir aber auffällt: dein USB device benutzt "using dwc_otg", steht gleich in der ersten Zeile ganz am Ende.
    Bei allen meinen linux-Rechnern mit usb-kabel und FTDI UART wird "using xhci_hcd" benutzt.
    Der USB 2.0-Port des CM4 verfügt über zwei Modi, den alten DWC- und den xhci-USB-Controller.
    Die alte dwc-Leistung ist nicht gut.
    Um auf den xhci-USB-Controller umsteigen zu können,
    folgenden Schritt mit einem editor (mc, vi, ..usw) durchführen:
    - Setzen otg_mode=1 in /boot/config.txt
    falls dort was anderes drinstehen sollte.
    dann mochmal booten und dann sollte in der ersten zeile am Ende "using xhci_hcd" drinstehen.
    Apr 10 11:53:57 raspberrypi kernel: [ 629.351345] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
    Den Eintrag anschauen kannst auch mit dmesg | grep usb
    Jürgen
  • Als USB Kabel hab ich folgendes verwendet: https://www.amazon.de/dp/B0758…o2ov_dt_b_product_details
    Ich habe genau das verlinkte CableCreation USB auf RS232 Seriell Kabel mit FTDI.
    Das Kabel sollte nicht Dein Problem sein.
    Bei mir schaut es auch so aus wie bei SolarEngel.
    In der ersten Zeile steht am Ende "using xhci_hcd".
    Habe eben mal bei mir die /boot/config.txt geprüft.
    Bei mir ist otg_mode nicht eingetragen.
    In der GUI kannst Du es prüfen:
  • Danke für die Tipps mit dem "xhci_hcd", werde ich gleich am Abend testen.
    Was mir noch aufgefallen ist: En Nullmodemkabel hat ja ausgekreuzte Belegung. Ich verwende aber kein Nullmodemkabel zwischen meinem USB Adapter und COM1 sondern nur einen Gender Changer. Wirkt sich das eventuell darauf aus dass keine Daten ankommen? Oder sollte der USB Adapter die Pinbelegung automatisch erkennen?
  • Hallo Manfred,
    so wie es aussieht bist RS232-seitig im Blindflug und mit der Ansicht es wird alles automatisch erkannt und automatisch eingestellt unterwegs.
    Dem ist leider nicht so. Aber eine serielle Schnittstelle ist ja keine Raketenwissenschaft.
    Es sind ja nur 3 Leitungen auf die es ankommt. RX an pin2, TX an pin3 und Masse an pin5 am SUB-D9 Anschluss.
    Das einzige was man vertauschen kann ist rx mit tx. Mehr gibts nicht zu vertauschen.
    Dafür gibt es auch fertige (RS232 cross-over oder Nullmodem) Kabel mit SUB-D9 Anschlüssen, da werden die beiden Leitungen rx und tx von der einen zur anderen Seite gekreuzt.
    Früher, in der Zeit wo es noch keine USB-Anschlüsse gab, hat man das öfters zum Anschliessen von RS232-Modems oder Direktverbindungen über RS232 zwischen zwei Computern gebraucht.
    An meinem seriell-to-USB Adapter mit Kabel sind 2 LED's für tx und rx Signal dran, da kann ich schon optisch sehen wenn sich Daten (rx,tx) auf der Leitung bewegen.
    Zum testen kannst ja anstatt dem Gender Changer(1:1) ein RS232 cross-over oder Nullmodem-Kabel hinter dem seriell-to-USB Adapter zum Kessel anschließen.
    Wenn ich mir nicht sicher bin, ob die Signale richtig oder überhaupt am Interface ankommen, dann muss ich halt messen mit einem Messgerät das digitale Signale anzeigen kann.
    Ein Logikanalyser, ein Oszi(galv. entkoppelt) oder ein Multimeter mit Digital-Funktionen(oszi). Solche Messgeräte sind inzwischen für jedermann erschwinglich.
    Wenn der RS232 Hardware Anschluss geklärt ist und die Signale rx und tx und Masse richtig am Interface ankommen, dann geht’s erst am Rechner weiter.
    UART-Einstellungen von Lambdatronic 3200 laut Handbuch mit Baudrate: 57600
    Wenn die Schnittstelle permanent ohne Aufforderung Daten liefert,
    dann kannst mit einem Terminal-Programm wie minicom oder cutecom oder PuTTY Daten vom ttyUSB0-Anschluss direkt einlesen.
    oder kannst in einem Terminal-Fenster den ttyUSB-Anschluss testen
    aktuellen Status von ttyUSB anzeigen
    sudo stty -F /dev/ttyUSB0 -a
    ttyUSB0 auf 57600 Baud einstellen
    sudo stty -F /dev/ttyUSB0 speed 57600
    64 Bytes von ttyUSB0 einlesen und im Hex-Format anzeigen
    sudo hexdump -C -n 64 /dev/ttyUSB0
    Daten von ttyUSB0 einlesen und in eine Datei schreiben
    sudo cat /dev/ttyUSB0 > daten.txt
    mit ctrl-c speichern beenden...
    Inhalt von Datei daten.txt anzeigen
    cat daten.txt
    oder mit jedem anderen editor anzeigen lassen, geht natürlich auch.
    Wenn Daten im Rechner angekommen sind, dann gehts weiter mit der Installation vom Linux - P4-Daemon (p4d)
    wie auf der Seite https://github.com/horchi/linux-p4d von horchi beschrieben.
    Der USB-Seriell-Konverter muss an COM1 des Fröling-Mainboards angeschlossen sein.
    Installation per Paket (aktuell verfügbar für Raspian Buster) Installieren
    wget http://www.jwendel.de/p4d/install-deb.sh -O /tmp/install-deb.sh
    sudo bash /tmp/install-deb.sh
    Jürgen
    Edited 2 times, last by SolarEngel ().
  • Danke "SolarEngel" für die ausführliche Informationen über RS232. Ich werde definitiv mal ein Nullmodem statt dem Gender Changer probieren.
    Welchen Adapter verwendest du denn wenn ich fragen darf?
    Kannst du mir da eventuell ein passendes Gerät für Einsteiger empfehlen?
  • Hallo Manfred,
    ja meine seriell-to-USB Adapter mit Kabel mit 2 LED's sind schon über 10 Jahre alt.
    Wo ich die gekauft habe und was sie gekostet haben weiss ich nicht mehr.
    So ziemlich ähnlich oder baugleiche hab ich bei Allnet oder KAEMSOFT gesehen.
    Ein sehr preiswertes LCD-Oszilloskop hab ich bei AliExpress (DSO2512G) gesehen für € 67,99.
    Ich selber bin OWON-Fan, habe zwei Geräte (HDS242 und SD8202), die kann man über USB oder Netzwerk fernsteuern,
    den Oszi-Schirm auf den PC holen und ein printscreen für Dokumentationen davon machen.
    Und noch viele weitere Funktionen wie Messwerte speichern usw.
    Die Messgeräte laufen auch schon einige Jahre problemlos bei mir und kann ich empfehlen.
    Logikanalyser hab ich von Saleae mit 16 Kanälen und USB-Anschluss
    und einen für den Raspi, den preiswerten Bitscope micro mit 8 Kanälen.
    Jürgen
    Edited once, last by SolarEngel ().
  • Um auf den xhci-USB-Controller umsteigen zu können,
    Also bei mir steht schon der Eintrag drinnen: otg_mode=1
    Trotzdem ist die Ausgabe bei bei dmesg | grep usb folgende:
    Code
    4.369846] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
    [ 4.529126] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
    [ 4.529167] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 4.529184] usb 1-1.3: Product: FT232R USB UART
    Also das Gerät läuft im dwc_otg Mode und nicht im xhci_hcd Mode.
    Ich warte mal bis das Nullmodemkabel da ist und probiere dann nochmal alles.
    Habe sicherheitshalber auch noch einen zweiten FTDI USB Adapter bestellt den ich ebenfalls mal probiere (https://www.berrybase.at/usb-r…rlaengerung-ftdi-chipsatz).
    Vielen Dank für die zahlreichen und wirklich umfangreichen Information. Echt tolles Forum hier!!
  • Also bei mir steht schon der Eintrag drinnen: otg_mode=1
    Code
    Mal ne blöde Frage, aber Du hast den RPi schon mal upgedatet?
    Dann habe ich hier noch was gefunden.
    Serial to USB, no ttyUSB0
    I'm trying to open a Serial communication between a Raspberry Pi 3 (model B, running on Raspbian) and a device (a traffic counter to be precise). I've a USB…
    raspberrypi.stackexchange.com
    Kein ttyUSB Gerät im SerialPort
    Ahh, wer lesen kann ist klar im Vorteil. Spielt die Reihenfolge eine Rolle, also erst modprobe und dann das echo oder wie tommi es geschrieben hat? PS: Was…
    community.symcon.de
  • Gute Neuigkeiten, habe heute das neue Nullmodem Kabel angeschlossen (statt dem Gender Changer) und es hat alles auf Anhieb funktioniert.
    Anscheinend waren wirklich die PINs nicht ausgekreuzt und deshalb ist kein Signal angekommen.
    Vielen Dank nochmal an alle hier die mir so super und im Detail geholfen haben :)
    LG
    Manfred
