Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/Vorlauf-Solltemperatur_0x16/state)[{"value": 21.5}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/BetriebsartHeizkreis_0x17/state)[{"value": 0.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/Boilertemperaturoben_0x5d/state)[{"value": 60.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/BetriebsstundeninderFeuererhaltung_0x73/state)[{"value": 95.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/Puffertemperaturoben_0x76/state)[{"value": 81.5}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/PuffertemperaturMitte_0x77/state)[{"value": 81.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/Puffertemperaturunten_0x78/state)[{"value": 58.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/SolarfuehlerPufferunten_0x8b/state)[{"value": 58.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/PufferpumpenAnsteuerung_0x8c/state)[{"value": 36.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/AnsteuerungKollektorpumpe_0x98/state)[{"value": 0.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/Kollektortemperatur_0xc5/state)[{"value": -1.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/EmpfohleneHolzmengebeimNachlegen_0x10a/state)[{"value": 2.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/SolarfuehlerPufferoben_0x12f/state)[{"value": 81.5}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/KollektorVorlauftemperatur_0x151/state)[{"value": -1.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/Pufferladezustand_0x1bf/state)[{"value": 94.0}]
Apr 14 23:52:08 raspberrypi p4d: -> (p4d2mqtt/sensor/Kesselzustand_0x1c9/state)[{"value": 3.0}]
Apr 14 23:52:08 raspberrypi p4d: Processed 31 samples, state is 'Heizen'
Apr 14 23:52:08 raspberrypi p4d: client 0xffffffff not found! [{"event": "all", "object": []}]
Apr 14 23:52:08 raspberrypi p4d: Updating error list
Apr 14 23:52:10 raspberrypi p4d: Updating error list done in 1619ms
Apr 14 23:52:26 raspberrypi p4d: State changed to 'Feuer Aus'
Apr 14 23:52:27 raspberrypi p4d: Got 2 unexpected bytes
Apr 14 23:52:27 raspberrypi p4d: -> (p4d2mqtt/sensor/Tuerkontaktschalter_0x0/state)[{"value": 104.0}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Heizkreispumpe_0x0/state)[{"value": 0.0}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Kesseltemperatur_0x0/state)[{"value": 8320.5}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Feuer Aus"}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Abgastemperatur_0x1/state)[{"value": 149.0}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Betriebsmodus/state)[{"value": "Dauerlast"}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/State_Duration_3/state)[{"value": 349.0}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Uhrzeit/state)[{"value": "Mittwoch, 14. Apr. 2021 23:52:19"}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Restsauerstoffgehalt_0x3/state)[{"value": 12.699999999999999}]
Apr 14 23:52:28 raspberrypi p4d: Got wrong communication id 0003 expected 02fd
Apr 14 23:52:28 raspberrypi p4d: Got 4 unexpected bytes
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x0004 failed, error -1
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/PositionderPrimaerluftklappe_0x5/state)[{"value": 0.0}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/PositionderSekundaerluftklappe_0x6/state)[{"value": 98.0}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Kesselstellgroesse_0x12/state)[{"value": 13.0}]
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x0013 failed, error -1
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x0015 failed, error -1
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Vorlauf-Solltemperatur_0x16/state)[{"value": 22.5}]
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x0017 failed, error -1
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Boilertemperaturoben_0x5d/state)[{"value": 0.0}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/BetriebsstundeninderFeuererhaltung_0x73/state)[{"value": 120.0}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Puffertemperaturoben_0x76/state)[{"value": 47.5}]
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x0077 failed, error -1
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x0078 failed, error -1
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/SolarfuehlerPufferunten_0x8b/state)[{"value": 58.0}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/PufferpumpenAnsteuerung_0x8c/state)[{"value": 116.0}]
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/AnsteuerungKollektorpumpe_0x98/state)[{"value": 0.0}]
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x00c5 failed, error -1
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x010a failed, error -1
Apr 14 23:52:28 raspberrypi p4d: -> (p4d2mqtt/sensor/SolarfuehlerPufferoben_0x12f/state)[{"value": 1.0}]
Apr 14 23:52:28 raspberrypi p4d: Got 1 unexpected bytes
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x0151 failed, error -1
Apr 14 23:52:28 raspberrypi p4d: Got wrong communication id 00a3 expected 02fd
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x01bf failed, error -1
Apr 14 23:52:28 raspberrypi p4d: Getting value 0x01c9 failed, error -1
Apr 14 23:52:28 raspberrypi p4d: Processed 20 samples, state is 'Feuer Aus'
Apr 14 23:52:28 raspberrypi p4d: client 0xffffffff not found! [{"event": "all", "object": []}]
Apr 14 23:52:28 raspberrypi p4d: 2) Alert for sensor VA/0x76, value 47,50 not in range (50 - 100)
Apr 14 23:52:28 raspberrypi p4d: 2) Alert for sensor VA/0x76 , value 47,50 changed more than 10 in 1 minutes
Apr 14 23:52:30 raspberrypi p4d: Send mail ' Puffertemperatur niedrig Puffertemperatur niedrig' to ''
Apr 14 23:52:30 raspberrypi p4d: 3) Alert for sensor VA/0x76 , value 47,50 changed more than 10 in 1 minutes
Apr 14 23:52:31 raspberrypi p4d: Send mail ' Puffertemperatur niedrig' to ''
Apr 14 23:52:31 raspberrypi p4d: Updating error list
Apr 14 23:52:31 raspberrypi p4d: Got 1 unexpected bytes
Apr 14 23:52:31 raspberrypi p4d: Updating error list done in 1ms
Apr 14 23:52:36 raspberrypi p4d: Got wrong communication id 0003 expected 02fd
Apr 14 23:52:36 raspberrypi p4d: Got 4 unexpected bytes
Apr 14 23:52:36 raspberrypi p4d: Error reading serial interface, reopen now!
Apr 14 23:53:27 raspberrypi p4d: -> (p4d2mqtt/sensor/Tuerkontaktschalter_0x0/state)[{"value": 0.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Heizkreispumpe_0x0/state)[{"value": 1.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Kesseltemperatur_0x0/state)[{"value": 77.5}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Feuer Aus"}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Abgastemperatur_0x1/state)[{"value": 119.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Betriebsmodus/state)[{"value": "Dauerlast"}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/State_Duration_3/state)[{"value": 349.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Uhrzeit/state)[{"value": "Mittwoch, 14. Apr. 2021 23:53:19"}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Restsauerstoffgehalt_0x3/state)[{"value": 18.800000000000001}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Aussentemperatur_0x4/state)[{"value": 0.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/PositionderPrimaerluftklappe_0x5/state)[{"value": 37.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/PositionderSekundaerluftklappe_0x6/state)[{"value": 3.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Kesselstellgroesse_0x12/state)[{"value": 98.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Abgas-Solltemperatur_0x13/state)[{"value": 163.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Vorlauf-Isttemperatur_0x15/state)[{"value": 22.5}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Vorlauf-Solltemperatur_0x16/state)[{"value": 21.5}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/BetriebsartHeizkreis_0x17/state)[{"value": 0.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Boilertemperaturoben_0x5d/state)[{"value": 59.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/BetriebsstundeninderFeuererhaltung_0x73/state)[{"value": 95.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Puffertemperaturoben_0x76/state)[{"value": 81.5}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/PuffertemperaturMitte_0x77/state)[{"value": 81.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Puffertemperaturunten_0x78/state)[{"value": 58.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/SolarfuehlerPufferunten_0x8b/state)[{"value": 58.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/PufferpumpenAnsteuerung_0x8c/state)[{"value": 0.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/AnsteuerungKollektorpumpe_0x98/state)[{"value": 0.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Kollektortemperatur_0xc5/state)[{"value": -1.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/EmpfohleneHolzmengebeimNachlegen_0x10a/state)[{"value": 2.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/SolarfuehlerPufferoben_0x12f/state)[{"value": 81.5}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/KollektorVorlauftemperatur_0x151/state)[{"value": -1.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Pufferladezustand_0x1bf/state)[{"value": 94.0}]
Apr 14 23:53:28 raspberrypi p4d: -> (p4d2mqtt/sensor/Kesselzustand_0x1c9/state)[{"value": 5.0}]
Apr 14 23:53:28 raspberrypi p4d: Processed 31 samples, state is 'Feuer Aus'
Apr 14 23:53:28 raspberrypi p4d: client 0xffffffff not found! [{"event": "all", "object": []}]
Apr 14 23:53:28 raspberrypi p4d: Updating error list
Apr 14 23:53:30 raspberrypi p4d: Updating error list done in 1636ms
Apr 14 23:54:27 raspberrypi p4d: -> (p4d2mqtt/sensor/Tuerkontaktschalter_0x0/state)[{"value": 0.0}]
Apr 14 23:54:27 raspberrypi p4d: -> (p4d2mqtt/sensor/Heizkreispumpe_0x0/state)[{"value": 1.0}]
Apr 14 23:54:27 raspberrypi p4d: -> (p4d2mqtt/sensor/Kesseltemperatur_0x0/state)[{"value": 78.5}]
Apr 14 23:54:27 raspberrypi p4d: -> (p4d2mqtt/sensor/Status/state)[{"value": "Feuer Aus"}]
Apr 14 23:54:27 raspberrypi p4d: -> (p4d2mqtt/sensor/Abgastemperatur_0x1/state)[{"value": 112.0}]
Apr 14 23:54:27 raspberrypi p4d: -> (p4d2mqtt/sensor/Betriebsmodus/state)[{"value": "Dauerlast"}]
